I just got an old Fluke 85 (one that predates the CAT rating). It measures voltage all right, and resistance sort of, but with open inputs it is fluctuating around negative 200kohms. First it looked easy, I checked all the usual suspects, that is everything has been already bathed in IPA, no burn marks anywhere, rotary switch cleaned, checked the VDRs, the fusible resistor, the input protection circuit (RV1, RV2, Q1, Q2, Q6, CR7, CR8, even removed these) but the problem persists.
So it is puzzling now, as I was suspecting one of these components to be failed after some overload, but apparently not.
Any tips on what else I should be looking next?
