Author Topic: QC35 headphones power switch replacement  (Read 938 times)
Offline sillygooseTopic starter
« on: November 16, 2020, 04:18:35 pm »
I have a pair of Bose QC35 headphones, for which the power switch has broken off. I was thinking of buying a broken pair of headphones to use as a donor to replace the switch, since that is the only thing wrong.
I've looked around for this kind of switch (note that the plastic switch bit is chipped off), but can't seem to find one anywhere. Is this a common kind of 3-mode, spring loaded switch or some proprietary bose stuff? I'd like to buy the switch instead of donor headphones.
The switch has two fixed positions for on and off, and a spring loaded third position for bluetooth settings.
Thanks in advance!
Offline pbarton
Re: QC35 headphones power switch replacement
« Reply #1 on: November 16, 2020, 09:09:38 pm »
Looks like https://www.aliexpress.com/item/32759056779.html
Also https://www.ebay.co.uk/itm/113317098300
However, these slide switches do not have the sprung loaded momentary position for bluetooth.
« Last Edit: November 16, 2020, 10:02:41 pm by pbarton »
The following users thanked this post: sillygoose
« Reply #2 on: November 18, 2020, 11:13:43 am »
Thanks!
The switches do seem similar, and I guess a spring loaded switch is not strictly necessary.
Offline pbarton
« Reply #3 on: November 18, 2020, 05:10:42 pm »
With a bit of luck, it may be possible to transfer the spring from the original switch into the replacement???
