Author Topic: Repairing TDS5000B acquisition board  (Read 1873 times)
Offline smaultreTopic starter
« on: July 27, 2021, 07:43:28 am »
Hello my friends, i need some help!
Got an 5054b board, with  memory, and some different errors on ACQ SELFTEST, one of the CY7C1361B-133AC goes hot( +5-15' than other).
After desoldering memory errors still present.
I have a dynamic channel lines on a very slow timescales, but when it start  to use more mem (high resolution), the screen with channels lines halt.
Trying to search where to buy some memory chips.. in the datasheet it says that mine use "2 chip enable", but i only found Cypress CY7C1361C-133AXC with "3 chip enable" functionality. I not clear understand what it means, they are compatible from up to down?
Can i install one chip Cypress CY7C1361C-133AXC with others CY7C1361B-133AC?
And also the diag routine says, that it fails on trigger on HITL and Nibble procs. Maybe The trigger ic is also BAD too?
I'm trying to make it to triggered on low frequencies as 5 to 30Hz but it did't TRIG'D ((
« Last Edit: July 27, 2021, 08:18:03 am by smaultre »
Start a new life here!!!
Online 2N3055
  • Country: hr
Re: Repairing TDS5000B acquisition board
« Reply #1 on: July 27, 2021, 08:14:34 am »
 CY7C1361B-133AC should be with 3 chip enables.
It should be exactly the same as CY7C1361C-133AXC , except CY7C1361C-133AXC is Pb-Free..
Check Pinout to be sure, but it should be it..
« Reply #2 on: July 27, 2021, 08:25:38 am »
Yes i'm sorry i found 3 different of pdf and make a mistake..
Now i got 2 groups of errors on "all"
1) ACQ -321
2)Trigger -442.
1) On ACQ:
-Memory -321
-ACQmodes -331
-HFStep -351
-Vertical-372
On Memory:
MemData -321
MemAddr-322
DataFormat-323
MemSpeed-324
On ACQmodes:
SubSample -331
PeakDetect -332
HiRes -333
On HFStep:
PhaseCal -351
On Vertical:
ADCConnects -372
2)On Trigger
-HITL -442 (on second test was gone)
-Niblle -461
On HITL (on second test was gone)
AfterDBE -442
On Niblle
Bus 461
Thats all )) Who can say something about Peak detect, PhaseCal, ADC connect, HITL, Nibble BUS... things??
« Last Edit: July 27, 2021, 08:56:23 am by smaultre »
Offline Jwalling
  • This is work?
« Reply #3 on: July 28, 2021, 12:36:52 am »
Have you read this? https://www.eevblog.com/forum/testgear/$200-reward-for-information-regarding-tek-tds5000b-debug/
Might be helpful...
Jay
System error. Strike any user to continue.
« Reply #4 on: July 28, 2021, 07:25:26 am »
Hello Jay.
 It's very interesting thread thank you for this information!
The log is attached on the first message is the full factory calibration log, it's very interesting!
Offline Jwalling
  • This is work?
« Reply #5 on: July 30, 2021, 08:47:52 am »
Hello Jay.
Did you try enabling the self test log on your scope? If so, can you post it?
Jay
« Reply #6 on: August 05, 2021, 02:45:50 pm »
Yes on the log it says that memory is bad. I awaiting for the new chips arrival.
Offline Jwalling
  • This is work?
« Reply #7 on: August 06, 2021, 08:34:27 am »
Could you please post the log?
Jay
Offline gianrisa
« Reply #8 on: April 28, 2024, 09:03:19 pm »
@smaultre were you been able to fix it especially the error 351 ?
« Reply #9 on: May 11, 2024, 06:37:10 am »
Hello! Yep, we fixed them, by changing about 8.. 10 memory IC-s.
