Author Topic: Quad 303 Recapping Question  (Read 1895 times)
Offline postman56Topic starter
« on: May 12, 2021, 01:02:28 pm »
I'm not a experienced tech here, so bare with me.
I want to replace the four larger power caps in my Quad 303 and they are all 2200 uF 100v DC.'s currently in there for from the manufacture.
The Blue caps in my photos.
I'm seeing Dada Electronics use the following in their upgrade package:
• 1x 4700μF 100V capacitor for the power-supply
• 2x 4700uF, 6800µF or 10.000µF 63V or 100V capacitors for the outputs
And I'm seeing others use four 4700uF in both the power supply and the speaker outputs.
I don't want to have to change any of the wiring connecting this to keep it simple but Dada recommends if using the 4700's as the upgrade the wiring needs to be a heavy gauge.
Should I jut replace them all with the original values, only high quality capacitors?
Any suggestions please would be welcome.
Offline fcb
    • Electron Plus
Re: Quad 303 Recapping Question
« Reply #1 on: May 12, 2021, 01:19:16 pm »
From memory there is a 67V regulator circuit on the negative rail of the PSU. So I probably wouldn't go overboard with the PSU capacitance and risk the bridge recifier.
Changing 2x2200uF for 1x4700uF should be fine.
Offline Jay_Diddy_B
« Reply #2 on: May 12, 2021, 02:50:27 pm »
I recapped my Quad 303 with 4x 4700uF. This is described in this message:
https://www.eevblog.com/forum/repair/quad-303-power-amplifier-power-supply-repair/msg1223778/#msg1223778
I used these parts from Digikey:
They are still available and reasonably priced.
I choose these parts to get a reasonable mechanical fit. The modern capacitors are small and metric. The originals are imperial dimensions. I increased the voltage and capacitance.
The amplifier has worked fine since this repair.
Best regards,
Jay_Diddy_B
« Last Edit: May 12, 2021, 02:52:08 pm by Jay_Diddy_B »
