Thanks - I haven't removed the board so I didn't notice the other side being populated - The scope has the 2M option installed. Does 2M cause the second side to be loaded?
TonyG
All the TDS700 series had both sides populated, whether they used 32K x 8 or 128K x 8 SRAMs. The 700C was the first that offered 2M, but unless it shipped that way they were only populated with the 32K chips. The 700D series from serial prefix B030 and up were all populated with 128K chips no matter what memory option it shipped with.
EDIT: B040 and up used burst type memory in quad flatpacks, IIRC.
I would suggest going through each channel one-by-one setting the memory depth to 2 million points per channel. Then with a sinewave applied try varying the vertical and horizontal settings and input frequency till some anomaly can be seen. I've never seen one of these scopes with failing ACQ memory not display some oddity or another. Until you at least determine which channel has the problem a repair would be difficult - imagine replacing all the SRAMs!
Also, have you tried running the ACQ tests in a loop for a few hours to see if the scope will pinpoint the failure? Sometimes you may get errors like this:
ERROR !!U307 MemAddr = 0x734600c data = 0xdb exp = 0x16 ,
ERROR !!U306 MemAddr = 0x734600a data = 0x37 exp = 0xac ,
ERROR !!U305 MemAddr = 0x7346008 data = 0xee exp = 0xd8"
