Author Topic: Quatro CTV-7230 TXT-S Repair  (Read 1933 times)
Offline Vince56Topic starter
  • Country: hr
« on: October 18, 2015, 06:14:36 pm »
I have a CRT Quadro who will not turn on. Signal red LED works, but there is no picture or sound. I do not know where to start to repair. If anyone knows what to do please tell. Greetings from Croatia .
Offline HighInBC
Re: Quatro CTV-7230 TXT-S Repair
« Reply #1 on: October 18, 2015, 06:22:46 pm »
I don't know what is wrong, but you should be aware that you can get a high voltage shock from a CRT even if it is not plugged in. The charge can remain in the CRT for a very long time after being unplugged. If you touch the wrong part you are going to have a bad time.
  • Country: hr
« Reply #2 on: October 18, 2015, 07:14:36 pm »
I am aware of high voltage parts, and take care to avoid them. By the way capacitors do not look bloated or burned.
Offline tec5c
« Reply #3 on: October 18, 2015, 10:46:47 pm »
Are there any strange buzzing noises coming from inside the unit when it is powered on?
  • Country: hr
« Reply #4 on: October 19, 2015, 08:17:48 am »
There is a very weak sound. Similar whimpering inductors.
  • Country: hr
« Reply #5 on: October 20, 2015, 06:55:46 pm »
UPDATE - The display shows the white line in the middle of the screen; Similarly in this figure
http://www.overclockers.com.au/wiki/images/e/e7/Electronics_001small.jpg
What could be
« Last Edit: October 20, 2015, 06:58:19 pm by Vince56 »
