Author Topic: Question about display issue in HP 8590A Spectrum analyzer  (Read 927 times)
Offline Johnny10Topic starter
« on: March 07, 2021, 03:26:29 pm »
I have been storing my HP8590A for about 4 months in a clean dry non-airconditioned space.
Turning it on yesterday I was greeted with the first screen below. (screen is stable in this distortion not flickering)
After a 2 hour turn-on time my screen was back to normal.
This morning 12 hours later screen is again stable.
What could be the issue?
« Last Edit: March 07, 2021, 03:56:36 pm by Johnny10 »
Tektronix TDS7104, DMM4050, HP 3561A, HP 35665, Tek 2465A, HP8903B, DSA602A, Tek 7854, 7834, HP3457A, Tek 575, 576, 577 Curve Tracers, Datron 4000, Datron 4000A, DOS4EVER uTracer, HP5335A, EIP534B 20GHz Frequency Counter, TrueTime Rubidium, Sencore LC102, Tek TG506, TG501, SG503, HP 8568B
Offline bob91343
Re: Question about display issue in HP 8590A Spectrum analyzer
« Reply #1 on: March 07, 2021, 08:56:02 pm »
Looks like a fault in the vertical amplifier.  Perhaps a bad connection.  I would open it and poke around with a screwdriver handle and see if I can make the problem come and go.  Wiggle all the connectors.
The following users thanked this post: Johnny10
Offline m k
« Reply #2 on: March 09, 2021, 06:45:55 pm »
Is it interlaced with dispositioned frames?
Advance-Aneng-Appa-AVO-Beckman-Danbridge-Data Tech-Fluke-General Radio-H. W. Sullivan-Heathkit-HP-Kaise-Kyoritsu-Leeds & Northrup-Mastech-OR-X-REO-Simpson-Sinclair-Tektronix-Tokyo Rikosha-Topward-Triplett-Tritron-YFE
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #3 on: March 09, 2021, 08:13:06 pm »
Guessing dry electrolytics in the CRT circuit.  Recap it.
Or replace the module wholesale, it's a somewhat standard display module -- or it was at the time, don't know how cheap/available spares are now.  I think some have even built LCD conversions, though the resolution is very nonstandard so it's a nontrivial process.
Seven Transistor Labs, LLC
Offline MarkL
« Reply #4 on: March 09, 2021, 10:25:53 pm »
There are different model monitors that HP used in the 859x series, but they should all have a vertical hold adjustment somewhere.  At least one model has it accessible through a hole in the top of CRT case and I think is marked.
Before doing anything drastic, I would try to find that pot first and give it a tap or a slight turn.  If no joy, you could also try doing the same thing to the vertical height adjustment.
