Author Topic: question about soldering irons please help  (Read 571 times)
Offline ThabetTopic starter
  • Country: ps
« on: October 07, 2024, 07:09:11 pm »
hello guys
is this a good soldiering iron ?
https://vi.aliexpress.com/item/32803295956.html?gatewayAdapt=glo2vnm
and in case its a good soldiering iron is this version good or you advice in another version ?
and another question what is the best handle to get 907 or p9 or m8 metal ?
and another question i see t12 c245 etc of tips what is the difference between them ?
im asking about the t12 because a friend of mine suggested that for me but he work with mobile boards i don't i only do consoles , pc , gpu , laptops and im not sure that why i asked ?
Online ataradov
    • Personal site
Re: question about soldering irons please help
« Reply #1 on: October 07, 2024, 08:01:13 pm »
This is a generic T12 soldering station. There are dozens of clones/variations. The overall design is generally fine with most of them, but build quality is pretty random as with any cheap Chinese product. I doubt you will find anyone with first hand experience with this exact version from this exact seller.
C245 tip range has higher thermal mass tips, but both are fine for general repair work.
Alex
  • Country: ps
« Reply #2 on: October 08, 2024, 03:19:16 am »
Ty for the help
Is there any solder iron that you suggest me that isn't too expensive?
Online ataradov
    • Personal site
« Reply #3 on: October 08, 2024, 04:51:36 am »
Those T12 stations are good enough as far as inexpensive stations go. I can't suggest a specific seller, I have not bough one for a long time.
Alex
  • Country: ps
« Reply #4 on: October 08, 2024, 05:58:16 am »
No problem about the reseller what about that exact modle is it good or I need to get other modle cause from what I know some of them have some issues like grounding for example
Online ataradov
    • Personal site
« Reply #5 on: October 08, 2024, 06:00:39 am »
No idea, as I said, there are a ton of them out there and new ones pop up regularly. Who knows what's on the inside even if the label is the same.
The best thing you can do is inspect it after you get one. Getting cheap stuff will always be a gamble.
Alex
