Author Topic: Bugs in KSGER C245 - how to solve?  (Read 771 times)
Offline repairMatthiasTopic starter
    • Matthias Weissers Infopage
« on: May 18, 2024, 10:21:04 pm »
I got a new KSGER C245. Unfortunately the software menu fails and the display output is not fully to see on the right side. Is there an easy fix getting rid of those problems? Are there schematics available for this device?
Re: Bugs in KSGER C245 - how to solve?
« Reply #1 on: May 18, 2024, 10:25:14 pm »
the character output is distorted. The device has to be switched off.
« Reply #2 on: May 18, 2024, 10:28:17 pm »
the °C text output is located too much to the right. The display should be shifted to the left.
Online DavidAlfa
« Reply #3 on: May 18, 2024, 11:08:59 pm »
Seems like a connection problem. Check the solder joints.
Offline Doctorandus_P
« Reply #4 on: May 19, 2024, 05:32:33 pm »
I agree with DavidAlfa that it's probably some connection problem. Maybe the flex to the display?
There are a lot of variations of very similar soldering stations, and both schematics, (KiCad projects) and firmware for variants can be found on github / gitlab and similar sites.
« Reply #5 on: May 20, 2024, 04:05:08 pm »
the display is working correctly when powered up. So I do not feel that this is a hardware problem. This happens when using this menu. Switching off the device and on and its ok. But it will happen again when using the menu again.
