Hi All,
Procured a Tekpower HY3010E dc supply from Ebay which was sold as "working". The Tekpower HY3010E has inherent short circuit protection as per the manual.
When I tried to set the current limit by applying a short at the output terminals, I cannot set a current limit of more than ~400mA.
However, if I try to set a current limit of 1A using 4.7V output and 4.7ohms load, that works fine and I can set the limit to 1A.
Is this normal behavior for a supply with "short circuit protection"? Do I have to use a load always rather than a short, to set the current limit?
thanks.....
