Author Topic: Question/Help with Original Xbox Clock Capacitor replacement option.  (Read 652 times)
Offline mictasTopic starter
  • Well I am stupid.
Hello all,
Well, I have two of these floating around, that will not keep time and while I have not opened either xbox, someone else has.
What I would like to do is order the replacement clock capacitors, before I go opening anything up and see what damage is or has been done.
With that, the one I have found is on RS https://au.rs-online.com/web/p/electric-double-layer-capacitors/7637860/ I was hoping someone with experience with swapping out these capacitors could tell me if this would work?
Thank you in advanced.
