Hello,
Recently I switched on my old 5342a and it behaved oddly, bizarre display initially then after a minute or two, the display shows a fixed display (looks like a series of segments are lit) on the LEDs. See photo below.
A quick look at the downloaded manual (
http://literature.cdn.keysight.com/litweb/pdf/05342-90057.pdf ) the fault finding tables, shows no response to keypad test then putting an oscilloscope (high z) on the HDSPWRT pin (supposed to pulse positive logic level on start up) shows no sig signal (only .2V 20kHz positive and negative spike, looks like switchPSU noise).
I am not an EE, and do not have the service extension cards so I have not spent a lot of time fault tracing; power rails test OK but it is looking like the microprocessor has failed on quick look. I see on ebay a few 'for parts' units with similar faults so assume it is a common failure.
If anyone has had a similar failure I would like to learn from their experience, I really dislike not maintaining good old gear but am getting a bad feeling about this. It is quite old gear and time spent fault finding may not be well spent.
Any comments/suggestions appreciated.
Rob Culver VK5RC
