Author Topic: Find Replacement Component/Component Identification for FLIR T4xx/B4xx Camera  (Read 1384 times)
Offline Chanc3Topic starter
Hello everyone
I've stripped down a B4xx series camera today as the operator was complaining that the down movement on the joystick was not working. Upon further investigation, it does work correctly if you apply a little bit of pressure and lightly tap down. I took apart the camera to identify the component as I believe one of the internal contacts is failing - funnily enough, this is the 3rd or 4th T4xx/B4xx I have seen with a broken joystick. I'm not an electronics expert, so don't know the correct terminology to use when looking for parts, so I'm hoping someone here can help identify the joystick I need to replace - please see the photographs below:
Few hours later, it turns out I should have been looking for a 5-way navigation switch!
eBay link here for anyone interested: http://www.ebay.co.uk/itm/361471159344
Part number is: SKQUDBE010
Alps Navigation Switch , 5Way , SMD
