Author Topic: Micro-Kim Repair  (Read 5001 times)
Offline SirWhyTopic starter
  • Country: ie
Micro-Kim Repair
« on: April 11, 2016, 08:05:30 pm »
Hey guys,
I'm an old school DIY computer lover, pouring a lot of time into Vince Briel's Replica-1 and Micro Kim kits, the software side anyway.
I recently picked up my Micro Kim again with the hopes of running some Microchess (because a 1k chess program is pretty cool) but after plugging in and resetting the board, no real signs of life. The power LED is on but the display (6 seven segment LEDs) won't light up. I then checked to see if serial communications were working but no joy. At this point I said it was time to pick up the oscilloscope and check some things out. Everything seems in order from what I can tell (troubleshooting isn't my strong suit) other than certain address lines not being pulled low on reset, although I can't trace where or why this is happening.
My best guess is the 6532 RIOT chip, however I thought I would check in with you guys first before dropping some cash on a potentially expensive replacement.
Normally this would go on Vince's forums but I can't seem to access them, so sorry for any unfamiliarity
Thanks in advance!
Offline sanman
Re: Micro-Kim Repair
« Reply #1 on: April 11, 2016, 08:15:18 pm »
Hit the R/S button and see if the displays light up. There is usually nothing on the displays @ power-up.
Offline PA0PBZ
« Reply #2 on: April 11, 2016, 08:16:26 pm »
Did you check the clock (pin 37 on the CPU)?
Any sign of life on PHI2 (pin 39 of the CPU)?
Does the EPROM still have valid data?
Is the address decoder working (U5)?
Do you see activity on the address  and data lines?
  • Country: ie
« Reply #3 on: April 12, 2016, 11:24:11 am »
Clock and PHI2 are good. No real way to test if the eprom has valid data at the moment.
U5 however has a little problem, pins 7 & 9 are meant to be high but aren't. A little tracing back and I find that at R20, we have 5V on one side but not the other, it may also be a cold solder joint that never gave trouble until now. Only little discrepancy is that even the lead on the other side doesn't seem to read 5V. Will heat it up anyway, I doubt the resistor has blown or anything, not with this system
EDIT: Pins 7 and 9 read 0.2V sorry, so next to nothing
« Last Edit: April 12, 2016, 11:28:16 am by SirWhy »
Offline PA0PBZ
« Reply #4 on: April 12, 2016, 11:45:01 am »
U5 is a BCD to decimal decoder, depending on the input ABCD one of the outputs /Y0 - /Y9 will be low.
Pin 7 will be low when the input is 0110, and pin 9 for 1110, so it could be normal that that the output is low: check the input or pull the jumper JP1, they should be high then.
K7 (pin 7 & 9) is the chip select for the EPROM, so if they are still low after pulling the jumper remove the EPROM. If still low it could be a bad U5 of course.
  • Country: ie
« Reply #5 on: April 12, 2016, 11:56:14 am »
Ok, took off JP1, all of them read high., with the jumper on the input is 0111 with K7 still low. Correct me if I'm wrong, but surely it should read high as that's a binary seven, pin 9 should read high off of that.
Offline PA0PBZ
« Reply #6 on: April 12, 2016, 02:21:22 pm »
Pin 9 is /Y7, binary 7.  Did you notice that one of the outputs goes LOW while the rest stays HIGH?
Offline stmdude
« Reply #7 on: April 12, 2016, 03:04:17 pm »
While I've never repaired (or even seen) a Micro-Kim, I do repair quite a few vintage computers and video games.
Things from this era usually hold together pretty well if they're stored somewhat decently.
However, we have reached the point where RAM and EEPROMs are dying of old age.  My troubleshooting list usually goes like this:
1. "Thou shalt check voltages"
2. "Thou shalt check your oscillator"
3. Probe CE/OE on the RAM+ROM, make sure they have flanks. Also, check one of the low address-lines on the ROM (not A0 in 16bit machines though), to make sure the CPU is trying to read something.
4. Probe every data-line on the ROM. Make sure there's no dead ones.
5. Same for the data-lines on the RAM.
If all that checks out, _actual_ troubleshooting starts. :)
Offline PA0PBZ
« Reply #8 on: April 12, 2016, 03:46:39 pm »
Other words, same list  :)
  • Country: ie
« Reply #9 on: April 13, 2016, 11:19:01 am »
Yep, it does that, even removed the chip and tested it on a breadboard. It's working fine.
So the problem may be a corrupted or bricked EPROM?
Offline PA0PBZ
« Reply #10 on: April 13, 2016, 11:52:10 am »
So U5 was a red herring? Back to the drawing board then.
Do you have a scope? check all address and data lines for activity.
  • Country: ie
« Reply #11 on: April 13, 2016, 01:13:29 pm »
Probed the lines and there's no activity on them just the one reading with no changes.
D0 - Low
D1 - Low
D2 - High
D3 - High
D4 - High
D5 - Low
D6 - Low
D7 - Low
A0 -> A15 are all high with no change
High in the case of the data lines is 5V but for the address lines it's only about 3.6V
Offline PA0PBZ
« Reply #12 on: April 13, 2016, 01:48:16 pm »
How about pins 2,4,6 and 40 of the CPU? They should all be high.
Offline stmdude
« Reply #13 on: April 13, 2016, 01:55:55 pm »
That's not right..  Lift the EEPROM + RAM + RIOT + U5 chips, and probe the address lines again.  If you still have no activity on the address-lines, I would presume that the 6502 have gone to the big ALU in the sky..
If the address-lines start twiddling with the EEPROM+RAM+RIOT+U5 removed, add them back one at a time, and probe in-between. That should give you an indication of which chip is messing with the address-bus.
( Or, do it the other way around. Remove one chip, test, remove next if it still doesn't look right )
Edit: My thinking behind this, so we're educating as we go along as well, is that the 6502 should be the only device that's _driving_ the address lines. Since we're not seeing a proper 5V on the address lines, something is preventing the CPU from driving the address-lines to their proper level.
By eliminating everything that's connected to the address-bus, we should be able to deduce which device is preventing this.
« Last Edit: April 13, 2016, 02:00:25 pm by stmdude »
  • Country: ie
« Reply #14 on: April 13, 2016, 02:15:44 pm »
All High
Took out the chips and the address lines now have activity (albeit at around 4V) so I think the 6502 is alright (for now). Will start putting chips in one by one
UPDATE: The activity on the address lines stop as soon as the RAM or ROM are put in their sockets. Also I notice that the address line activity isn't very clean or predictable, there is also some weird activity on the data lines (even when all chips are removed)
Edit: Ok, so adding them in again and the activity on the data and address lines looks good only at around 3.7 - 4V. Adding in the RIOT chip puts an end to this, bringing me back to the idea of the RIOT chip being the problem.
« Last Edit: April 13, 2016, 02:43:33 pm by SirWhy »
Offline stmdude
« Reply #15 on: April 13, 2016, 03:54:39 pm »
That would have been my conclusion as well.
Jameco seems to have them in stock for $7 each.  http://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?langId=-1&productId=43297&catalogId=10001&freeText=6532&app.products.maxperpage=15&storeId=10001&search_type=jamecoall&ddkey=http:StoreCatalogDrillDownView
