Author Topic: Quick Repair: Standford Research PS350 5KV 5mA(Fixed but working on calibration)  (Read 11542 times)
Offline nexus
If required i can make an executable you would then only need to download a free runtime engine to get it working.
Hi Dexter; appreciate all the work you and others have shared on this very useful thread. If you have an executable for the PS350 program you wrote, that would be great!
Offline nexus
Hi all,
I downloaded labview and compiled the PS350 calib that Dex wrote from a VI into an EXE. You should be able to run it with the LabView runtime only.
I just completed a user calibration on my PS350. I used a B2902A SMU to calibrate current (around 100V) and used a DMM6500 with a caddock HVD5-A50M-050-05 divider to do the high voltage adjustments.
To compensate for the divider error I measured the ratio before starting (mine was 49.978 M over 50.032 K).
Also wrote a text file to record values as I manually tuned them. This was helpful to guide the adjustment procedure.
