Author Topic: Quick Samsung PSU Capacitor Question...  (Read 3131 times)
Offline urbisTopic starter
« on: January 01, 2015, 06:36:40 pm »
Hello,
I'm looking at a friend's Samsung TV with bulging caps, however, as seen on the picture below, the two on the right hand side are 820uF, which seems to be awkward to find:
Looking at the bottom of the board, they seem to be wired in parallel, therefore, my question is which would be best:
1x 1000uF Cap replacing one, and a 680uF cap replacing the other.
Or
2x 1000uF Caps
Cheers!
Offline tautech
Re: Quick Samsung PSU Capacitor Question...
« Reply #1 on: January 01, 2015, 06:51:26 pm »
As they are straight after the rectifier diodes and subject to a good amount of ripple, I would select good  quality Low ESR, high ripple 1000 uF replacements.
If physical size of diameter looks tight, get taller if you have the clearance.
Check there is sufficent voltage headroom also, manufacturers run caps too close to their rated voltage IMO.
We do ourselves no favors by skimping on a repair of this type.
Get some extras.....you will use them.
Offline justanothercanuck
  • Doing retro repairs...
« Reply #2 on: January 01, 2015, 08:50:08 pm »
I would go with 2 1000uf caps, they're a common value, so they're easy to stock up on.  :-+
Maintain your old electronics!  If you don't preserve it, it could be lost forever!
« Reply #3 on: January 01, 2015, 08:59:35 pm »
Had a couple of 1000uF caps lying around, now up and running.
Cheers guys.
Offline tom66
« Reply #4 on: January 01, 2015, 10:11:21 pm »
Just a note with these Sammy's, replace every single capacitor on the secondary. They are all bound to fail sooner or later.
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #5 on: January 02, 2015, 02:56:55 am »
More is almost always better.  The only reason it might not be, is if it screws with the power supply controller's response time (and it breaks into oscillation or something bad like that).
For the same reason, high performance, low ESR caps may not be ideal, either -- these sorts of circuits are a triumph not only of engineering to a cost, but to a time as well!
Seven Transistor Labs, LLC
Offline Yago
« Reply #6 on: January 02, 2015, 12:25:37 pm »
Is that a case of searching for the ESR specs of mystery caps, or is there a rule of thumb?
Offline tom66
« Reply #7 on: January 02, 2015, 04:10:37 pm »
I have always used Panasonic FC/FM/FR as they are good midrange caps and never had an issue, probably 20 PSUs recapped now, if not more, all worked first time (when the caps were the fault)
