on the plus side I just aquired an old nixie voltmeter from Meratronik with good documentation.
Now I figured it has a offset of about 160 mV in the 10 V measurment range,but I can't calibrate it, as the total potentiometer travel only does a 10 mV change.
I also tried calibrating the 1V range there is only a 5 mV difference but changing the potentiometer does absolutely nothing there.
(Yes, I made sure to warm it up and turn the right potentiometers, according to documentation).
Anyone had this fault before?
What point can I start analysing the issue?
Thanks in advance.
