Author Topic: For your amusement. May or may not have been produced in China.  (Read 13108 times)
Offline wilgilTopic starter
Spot the problem.
« Last Edit: April 10, 2015, 07:38:19 am by wilgil »
Offline pickle9000
Re: Qwalitee Chineeese electronics.
« Reply #1 on: April 09, 2015, 06:33:01 am »
I done see any issue. The one chip just want to mate with the other one. That's how pcb's are populated.
Online Ed.Kloonk
  • Cat video aficionado
« Reply #2 on: April 09, 2015, 06:42:44 am »
iratus parum formica
Offline zapta
« Reply #3 on: April 09, 2015, 07:07:15 am »
R2 and R5 rotated? That's nitpicking.
Offline Tim F
« Reply #4 on: April 09, 2015, 10:16:25 am »
Come'on man, we all know that if this was an audiophile product all the electrons would go the wrong way and pace, rhythm and timing would be messed up.
Offline Grapsus
« Reply #5 on: April 09, 2015, 11:47:55 am »
Maybe the board was being shipped to Australia and the chip tried to turn itself the other way ?
Offline ConKbot
« Reply #6 on: April 09, 2015, 04:11:21 pm »
Excess capacitance from the crystal leads being so close probably detuning it a bit.
Offline LabSpokane
« Reply #7 on: April 09, 2015, 04:29:45 pm »
It doesn't matter. Because I'm pretty certain that the DS1307 on that is counterfeit anyway. The backup battery will charge off Vin, which it is definitely *not* supposed to do. It does keep and report time correctly.
A workaround is to use a controller pin to supply Vin and only power up the clock when you read the time. That will hopefully keep the battery from bursting in the near term.
Offline elgonzo
« Reply #8 on: April 09, 2015, 04:43:49 pm »
It says "Tiny RTC I2C modules" but it obviously is just a single "Tiny RTC I2C module". Typical case of Chinglish, i would say. Everything else seems to look fine...  ;)
« Last Edit: April 09, 2015, 04:45:23 pm by elgonzo »
Online oPossum
« Reply #9 on: April 09, 2015, 04:47:37 pm »
Trace out the battery circuit if you want to see the real WTF with that module.
Offline free_electron
    • SiliconValleyGarage
« Reply #10 on: April 09, 2015, 04:56:48 pm »
they are using the wrong FONT ! it;ll never work right ...
Offline M4trix
  • Country: hr
« Reply #11 on: April 09, 2015, 05:02:51 pm »
I guess R7 is missing otherwise I don't see anything wrong.  :-//  ;)
Offline elgonzo
« Reply #12 on: April 09, 2015, 05:11:18 pm »
Oh no, the component ID for R2 is printed incorrectly. I don't understand how this could pass QC. Servicing this device will become a nightmare...
Offline AlfBaz
« Reply #13 on: April 09, 2015, 05:22:34 pm »
I've never had the opportunity to be "The One Who Starts" so fuck it, I'll give it a red hot go before somebody else chimes in...
I am not comfortable with the title of this thread made worse by the stereo-typical bullshit misspelling. If I was Chinese I'd be pretty pissed right now.
Further more the shit in that photo can happen to anyone with zero quality control. So what do you want dirt cheap electronics AND quality control?
Expectations in this instance say more about the finger pointers than the mob manufacturing it
There, how'd I go?
Offline LabSpokane
« Reply #14 on: April 09, 2015, 05:31:00 pm »
It is faster, easier, and better just to draw up the schematic and  send it off to Oshpark.  What I should have done to begin with... How does one hose up connecting a battery to two pins?!
Offline LabSpokane
« Reply #15 on: April 09, 2015, 05:42:13 pm »
There, how'd I go?
Fine by me.  I don't care for the national/racial bashing either. For all these cheapo boards, no one should expect more than reject parts and zero QC.  The Chinese are matching the quality to a price point. I actually think it's good business because they are taking what would otherwise get scrapped and building useful learning devices from them.
For my part, I am the only one to blame for being to lazy to spin a board instead of buying a cheapo RTC off ebay. That board should work if the IC is moved back.  Just don't leave it on Vcc for an extended period or the battery will leak all over.
Online oPossum
« Reply #16 on: April 09, 2015, 06:00:13 pm »
It's easy to fix the battery WTF. Instructions here... http://forum.43oh.com/topic/4131-ds1307-rtc-eeprom-from-ebay-possible-unreliable-operation/
Not just a problem with the 'charging' circuit. There is also a voltage divider between the battery and the DS1307!
Offline pickle9000
« Reply #17 on: April 09, 2015, 07:31:02 pm »
Things like this never (I hope) make it into an actual production device. I am thankful that this and many other things are readily available on ebay. No way could I afford the variety of these types of items I keep in my junkbox. Even the one in the image 5 minutes to fix and if I needed it for whatever there it is, no waiting.
Offline LabSpokane
« Reply #18 on: April 09, 2015, 07:41:53 pm »
For me, this was the kick in the ass I needed to apply myself to designing PCBs and getting stuff out the door.
Personal growth courtesy of failure. Thanks, China!!
Offline McBryce
« Reply #19 on: April 09, 2015, 07:45:38 pm »
It's an RTC module. You obviously took the photo at 11:00. Wait another hour and the chip will be back pointing to 12:00.
McBryce.
Offline pickle9000
« Reply #20 on: April 09, 2015, 07:50:14 pm »
McBryce.
Awesome!
« Reply #21 on: April 09, 2015, 08:01:30 pm »
McBryce.
Awesome!
+1
Good first laugh of the day.  :-+
@Wiigil
UNO kit board is it?  ;)
« Reply #22 on: April 10, 2015, 07:57:08 am »
There, how'd I go?
I am surprised then that you are such an active member here, considering that the owner of this Forum is quite verbal in his opinion of the poor QC of some inexpensive Chinese electronic items, often quoting 'One Hung Low' brands. Please direct me to your posts where you treat Dave like crap for some of the comments he makes on his videos.
I have changed the title of this thread for you. I trust that you are more comfortable now.
This item was supplied to me by a Chinese importer, who is fully aware of the problem.
We had a laugh together about the mistake - he's going to send the photo to his supplier. I wasn't particularly worried, as the RTC was a freebee, included with a large order of items destined for educational purposes, and it only took a few seconds to fix.
I merely posted the photo here to bring a smile to people, not in order to be judged by people who have never met me.
I apologise for any offense caused.
« Last Edit: April 10, 2015, 07:59:05 am by wilgil »
Online Ed.Kloonk
Re: For your amusement. May or may not have been produced in China.
« Reply #23 on: April 10, 2015, 08:58:29 am »
Please change thread title back to original. Please also extend an erect finger toward those who feel it is their responsibility to be offended on behalf of other people. What a hide.
Offline Grapsus
« Reply #24 on: April 10, 2015, 11:10:09 am »
Welcome to the new age of political correctness where organizing a barbecue gets you remarks about how unfriendly you are towards vegetarian people.  :palm:
