Hello guys!
I have a problem with my graphic card. I tried to turned on computer but it only beeps, one long and three short, it is the gpu failure.
So i measured with voltmeter and the 270uf 16v capacitors(7 of them) have 12v voltage but the other ones not, 10 of them ( 820uf, 3V). This is what i know so far
And on 2X8 PIN power supply there is voltage. And i tried other graphic card and it works ok, so other components are ok.
Is there any way how to determine faulty component on Gpu board and how?
Please i want to make it work if there is some way?
Thank you
Regards.
