Hi EEVBlog forum,
although it is my first post I have received lots of help in this forum thanks to the contribution of all members, so I thought I could give some contribution back and here goes my ongoing Racal 9081 repair... (btw sorry for any english grammar error, I can not blame google for it only myself
Just to contextualize, this instrument belongs to me for many years but I've not been using it for about 2 years now, and the day I needed it... well.. it just don't start.
I'm aware of the tantalum fault of those instruments, and after opening it up and checking the different power supplies voltages there was no 12V - a quick measurement on the output shows a short to ground and after desoldering the 7812 output I get 11,95V, so regulator is OK.
I've started to look for visual fault and found 3 smocked resistors, R24+R81 on "FM LOOP ASSEMBLY 19-0844" board and R63 on "LOGIC ASSEMBLY 10-0842" board. All connected to a power supply line and with associated tantalum cap shorted (C16+C46+C30) - so the tantalum cap story begun!
After replacing all those components I continue to get 12v shorted. I've started to follow the 12v line (trought wires) - not an easy task I can say! - and found another shorted tantalum!!! new cap on and finally get something on display counter!
but frequency is always jumping up and down
I then thought and thought and... started my tantalum journey:
replacing all the tantalum caps and a full renewing of this instrument! I'm I crazy? did anyone tried this before? I hope so, can not be alone on this
I make a list, ordered caps and started to replace them board by board. So far so good - after replacing caps on one side o the 9081, frequency is not jumping any more, but cannot ajust it with spin wheel yet
, however switch range is apparently working fine.
An example of result before going to the other side of the 9081
and after - no more red drops!
stay tuned!
