Author Topic: Racal RA6790/GM  (Read 409 times)
Offline simba15Topic starter
Racal RA6790/GM
« on: August 14, 2023, 06:08:39 pm »
So my repairs continue down the line!
I have a Racal 6790 that is not in good shape, the dreaded backup battery leaked!
It power on and has a real fit!~  All displays light, then the freq display goes blank.
I cleaned some corrosion off the board and tried again.
This time, messing with the power switch ( on-off a few times) the freq display will work and even change with the main knob, but only for 500ms, after this the Fault light comes on.
Power rails all test ok, I suspect the fault is with the A6A2 Board.
The tantalum caps seem ok (C13,C14)
C17 on the other hand seems iffy, Across reads ~40ohm, but once removed, Q7 Drain is still ~40ohm to gnd (this is the reset line to the CPU)
I noticed that Q7 and Q6 are listed as TIS74 but on my board they are 2N4392. Can I replace with TIS74?
Any ideas if these values are OK, or should I start replacing Q7, caps, ect.
Offline w3jn
Re: Racal RA6790/GM
« Reply #1 on: August 14, 2023, 07:46:12 pm »
Before you go any further, check the filter caps.  I had a 6790 that acted really wonky; all the filter capacitors were pretty much open and the regulators weren't able to deal with the ripple.  Just poke at each power supply output with your meter on AC; the ripple will show its ugly head if the caps are bad.
