Author Topic: Radio Shack Frequency counter model 22-306 gone deaf.  (Read 9045 times)
Offline LightagesTopic starter
  • Canadian po
« on: January 12, 2015, 08:37:02 am »
I seem to remember somewhere on the internet a comment made by someone about the front end amplifier getting fried easily on the 22-306. Mine is basically deaf and I was looking around but found nothing.
There is this thread on the forums about another repair:
https://www.eevblog.com/forum/repair/radioshack-22-306-frequency-counter-teardown-and-repair/msg155276/#msg155276
But it does not relate to my problem. I remember the front end amp transistor being something like MFJ47 or something like that but I am sure I am wrong. Anybody have any schemattics, links, suggestions?
Offline Alex Eisenhut
  • Place text here.
Re: Radio Shack Frequency counter model 22-306 gone deaf.
« Reply #1 on: January 12, 2015, 05:04:25 pm »
Hmm, I have the service manual somewhere.
  • Place text here.
« Reply #2 on: January 12, 2015, 06:02:40 pm »
Just some quick n dirty camera shots.
  • Place text here.
« Reply #3 on: January 12, 2015, 06:10:57 pm »
troubleshooting chart
I'd go through the basic power supply - reset ckt - oscillator checks first.
But the thing uses a center negative barrel connector for external DC and it's not smart enough to tell alkalines from nicads by itself, you have to set a switch.
If by "deaf" you mean "no display at all", yes, check the whole power supply section first. One hopes it's not the processor that's fried.
  • Canadian po
« Reply #4 on: January 12, 2015, 06:11:23 pm »
That is very helpful Alex! Thank you.
Is there any chance of you scanning the whole document and making it available to me in some form? I am willing to pay a fee.
  • Canadian po
« Reply #5 on: January 12, 2015, 06:13:36 pm »
It is functioning but not displaying stable values and it does not respond to sufficiently large amplitudes as it should.
  • Place text here.
« Reply #6 on: January 12, 2015, 06:58:59 pm »
I'll think about it, the Canon scanning software is atrocious, I gotta see if I can use something else to stitch together 20 or so scans into a PDF.
When you scan a manual, alternate pages are flipped but there's no simple way to tell the stupid software about it.
  • Canadian po
« Reply #7 on: January 12, 2015, 10:07:56 pm »
Don't worry about the order or orientation of anything. If you have the time, just scan to jpgs or whatever. I will sort it out on my end.
Offline JoeO
  • I admit to being deplorable
« Reply #8 on: January 13, 2015, 03:50:44 am »
How about this?
http://www.radioscanner.ru/forum/topic45103.html
3rd post down from the top.
The day Al Gore was born there were 7,000 polar bears on Earth.
Today, only 26,000 remain.
  • Canadian po
« Reply #9 on: January 13, 2015, 04:16:37 am »
JoeO:
Thanks for the link. I am not sure it is useful though as all the jpg file names reference the 22-305
Offline JoeO
« Reply #10 on: January 13, 2015, 12:14:24 pm »
Sorry:  I put 22-306 into Google search and I never noticed that they listed 22-305 as a result.
  • Place text here.
« Reply #11 on: January 13, 2015, 04:12:25 pm »
alright alright, I'll try to use the scanner... It's only 24 pages.
  • Canadian po
« Reply #12 on: January 13, 2015, 05:14:20 pm »
I appreciate the effort. Thank you
Online PA0PBZ
« Reply #13 on: January 13, 2015, 07:59:27 pm »
On what range is that?
  • Canadian po
« Reply #14 on: January 14, 2015, 01:03:18 am »
I don't remember exactly the conditions of the failures. I am sure though that it does not work on the low range.
Online PA0PBZ
« Reply #15 on: January 14, 2015, 09:17:07 am »
I'm asking because each of the ranges follows a different path:
1Hz - 10Mhz: Directly to U3
1Mhz - 50Mhz: This uses the pre-amp on the top left, then the prescaler U4
50Mhz - 1.3Ghz: Goes directly to the prescaler U4.
So knowing where the problem is would be helpful in finding what's wrong.
  • Place text here.
« Reply #16 on: January 14, 2015, 08:13:42 pm »
My scanner finally connected again to my wi-fi router. Don't know why Canon makes such opaque, bloated, and bizarre software. "Please wait a while" indeed.
I miss my old cheap and cheerful flatbed USB scanner.
  • Canadian po
« Reply #17 on: January 16, 2015, 09:18:55 pm »
Thank you very much to Alex for his help and time with the service manual. It will be very helpful.
PAOPBZ, yes I now have a path to follow, thank you.
  • Place text here.
« Reply #18 on: January 16, 2015, 10:58:37 pm »
It may eventually also show up at BAMA in the Radio Shack section. I am so annoyed at the Canon software that I skipped trying to stitch the schematic pages together.
Canon makes one of the worst software suites I've ever seen. Makes Sonic Stage look like iTunes.
