Author Topic: Rainbow vertical lines on display  (Read 2669 times)
Offline KopernikTopic starter
  • Country: si
« on: August 29, 2016, 08:58:14 am »
Hi!
I have problem with operational panel.
It have a mixed rainbow vertical lines on display that is connected thru LVDS connection.. if I connect external monitor thru VGA, the screen is OK.. I changed S3 VIA twister bga chip, but the problem is the same.. the motherboard is PCM-9371..
Any suggestions?
Online wraper
  • Country: lv
Re: Rainbow vertical lines on display
« Reply #1 on: August 29, 2016, 09:18:01 am »
Have you changed actual LCD panel because is sounds exactly like faulty panel? Also a picture is welcome.
The following users thanked this post: Kilrah
  • Country: si
« Reply #2 on: August 29, 2016, 09:46:40 am »
No, I didn't change display, because I'm not 100% sure what's wrong..
here's a picture of display.
Offline Kilrah
« Reply #3 on: August 29, 2016, 10:01:14 am »
The display panel itself or TCON would be the most likely culprits. Trying another panel would be the first thing to do.
  • Country: si
« Reply #4 on: August 29, 2016, 10:06:12 am »
I have another panel, but it have different connector.. I'll try to connect it...
Thanks
Online wraper
  • Country: lv
« Reply #5 on: August 29, 2016, 10:32:13 am »
Well, changing BGA as first measure when you are not sure...  :-//
Yep, looks like faulty panel. Of course not guaranteed, but probability is very high.
In this case T-CON most likely is part of the LCD panel and is not exchangeable.
  • Country: si
« Reply #6 on: August 29, 2016, 11:25:33 am »
Yes.. t-con is a part of display..
What if i try to change main chip on display?
It's AUO072.
It cost 2$ from china..
Offline jkf1000
« Reply #7 on: August 29, 2016, 12:24:40 pm »
Not familiar with the LVDS, but that display looks to be exactly the same issue as a machine I have on the bench at the moment. The one I have is missing its HSYNC/VSYNC signals from the main video processing chip due to corrupted data or faulty MPU.. Karl
Offline bktemp
« Reply #8 on: August 29, 2016, 01:59:19 pm »
That would be my guess too.
So before changing the T-con check if the input signal is ok.
