Author Topic: behringer od300 effects pedal  (Read 462 times)
Offline andybarrett1
« on: January 19, 2018, 03:15:39 am »
Hi
Thank you for reading... Can any body help me with the schematic or help ID this Chip (IC1)
I want it to be a op-amp but really not sure
BR
Andy
Offline Andy Watson
Re: behringer od300 effects pedal
« Reply #1 on: January 19, 2018, 03:37:35 am »
Most likely a quad op-amp - would need to see more of the surrounding circuit to be sure:
http://www.st.com/resource/en/datasheet/tl064.pdf
Offline floobydust
« Reply #2 on: January 19, 2018, 08:08:14 am »
It is a TL064C made by ST, quad op-amp.
Behringer stuff is pretty cheap inside, the electrolytic capacitors are very low quality and cause problems. First thing I check.
« Reply #3 on: January 19, 2018, 07:15:30 pm »
Hi All
TL064C
I can see it now...... Thank you for replies.
BR
Andy
Offline kalel
« Reply #4 on: January 19, 2018, 08:29:45 pm »
Sorry for off topic but just curious, which brand (preferably not overpriced) would you recommend for guitar effects, that is known for decent quality components?
« Reply #5 on: January 19, 2018, 09:03:57 pm »
Hi
From a repair point of view all the pedals I have seen are a much of a muchness  .... Hand wired EFX and Amps are an exception !
BR
Andy
