Hi
Just because one company does not go in for IP protection does not mean that a company in a *very* different business also looks at it the same way.
Bob
Dear Bob,
I am trying to repair something for free for a close relative, I am well aware that the "letter" of the law gets you fined, but most of us
in our daily life follow the spirit of the law. Let´s not make this post about what is legal or what is not, I´m trying to find in the end someone,
who has experience with repairing these systems to throw around some hints and if they can some "help", when not it is like this, I´ll have to accept it.
If you have a scope, its a good idea to check the digital lines of the logic, rom, eeprom, clocks etc. Digital logic can fail without becomming hot. Sometimes the risetimes become to slow, or they can't get to a logic level, and get stuck somewhere in between.
I do have access to a scope, although I´ll have to transport the unit. Guess a DSO can only get you thus far, that this is a toy, I can not for now check faster signals.
They do use some 74HC04 with some crystals which don´t seem to do anything although they are powered normally and the board was for sure repaired before as
there is a clear mismatch with some ICs, most are from Toshiba and then somewhere a small Hitachi with some small flux residue.
It was a bit strange to see that they don´t use any filtering with the crystals (which I think are resonators not crystals but with no middle ground pin). Just the crystal
straight to the IC. Don´t get me wrong it works but, it´s exactly like this, you power up the thing one day and it doesn´t anymore.
Although I don´t expect to see anything with the DSO, it could have been that I would be able to see some heavily aliased signal. True enough I need access to a real
scope though, I have no illusions.
Oddly enough, most repair videos that I have seen in that sense, like from Signal Path, the problem could be with the RAM, which will be a pain the the ass to retrofit
as the original ICs are in SIP package.
I´ll get the thing under a real scope and have a go with it, it´s not that complicated after all.
BTW does someone know by experience the average data retention time for UV erasable EPROMs like the AM27C512 here? The unit should be at least 20 years old,
but the EPROM failing is really strange. In the end that´s what I was told by the previous "engineer", who had a go with repairing it. I don´t want to be biased in my
approach.
Thanks for your time and advice, for me it´s a quite interesting repair so I´ll keep you informed, if anyone has more suggestions I am in debt!
Cheers,
Lefteris
