Author Topic: Re: Capacitor replacement  (Read 784 times)
Offline rivestTopic starter
« on: August 04, 2022, 08:27:01 am »
Hi guys, what's a suitable replacement for this Jensen cap? They stopped production back in 2019.
I'm not sure of the function of this giant cap but it is for a welding power supply card.
1557532-0
Online jpanhalt
« Reply #1 on: August 04, 2022, 08:35:30 am »
How do you know it's bad?  My TIG welder (Miller Synchro brand)  is from 1983 and still has its original capacitors.
Offline TheNewLab
« Reply #3 on: October 17, 2022, 12:20:52 am »
Not sure if this helps. That is likely a really large capacitor. Testing if it is good, using a Blue ESR meter or simiare Dick Smith design is a quick test equipment tool. can also test in-circuit.
kinda sorta related? questions regarding using different type of caps? over at
 https://www.eevblog.com/forum/repair/capacitor-re-cap-maddness-blue-esr-meter-alternate-type-capacitors-st-receiver/msg4467430/#msg4467430
