Author Topic: Re-lacquering PCB's for outside usage?  (Read 2913 times)
Offline Chris WilsonTopic starter
  • Race car engineer, dog lover, hoarder.
« on: April 07, 2015, 11:33:58 am »
I have some expensive outside radio linked PIR sensors and 2 have suffered water ingress. I eventually found the reason they were intermittently faulty was the coating on the PCB's had become slightly conductive and op-amps were doing "funny things". I soaked and washed the boards after dismantling the devices in isopropyl alcohol and dried them slowly. I have found some coatings go soft and are removed by IPA, and some are unaffected. This stuff came off in minutes. They now work fine but I fear usage in an outdoor environment may cause PCB track degradation. I would like to re-coat them with a water proof varnish of some kind. has anyone any experience as to what to coat them with please? Thanks!
Best regards,
                 Chris Wilson.
Offline android
Re: Re-lacquering PCB's for outside usage?
« Reply #1 on: April 07, 2015, 11:44:27 am »
You could try Electrolube DCA SCC3 Conformal Coating. I bought a 200ml spray can recently, but have to admit to not actually using it yet. You can solder through it later if you need to. Pricey though.
Lecturer: "There is no language in which a double positive implies a negative."
Student:  "Yeah...right."
Offline tautech
« Reply #2 on: April 07, 2015, 11:47:24 am »
Here's a local one for you:
http://uk.rs-online.com/web/p/electronics-varnishes-lacquers/0569290/
I use similar one all the time in our humid climate, even on new home etched PCB's before soldering.
Good for touch ups after rework too.
« Reply #3 on: April 07, 2015, 12:00:00 pm »
Excellent, RS are convenient as I need some other stuff that I can add on to get free P&P. Thanks for that!
Best regards,
                 Chris Wilson.
Offline madires
  • A qualified hobbyist ;)
« Reply #4 on: April 07, 2015, 12:32:23 pm »
CRC's SK10 works fine for me. SK10 is flux and lacquer in one, but it's not a conformal coating. I got old home automation stuff I made over 20 years ago and the PCBs still look like new (some mounted in a moisty environment).
« Reply #5 on: April 07, 2015, 04:04:36 pm »
If you only have a few use some 2 part clear epoxy after cleaning the board to coat the boards on each side. Cover all components and wiring so that moisture does not get to the copper.
Offline wagon
« Reply #6 on: April 08, 2015, 01:49:00 pm »
If you are really tight for funds you can use a clear 'enamel' paint in a pressure pack can.  Do a couple coats.  Works OK, and is good considering you can buy a can of it for about $5.
Hiding from the missus, she doesn't understand.
« Reply #7 on: April 08, 2015, 02:03:19 pm »
Got the RS branded spray coming as per tautech's link, hopefully it will do the job, with luck they'll last another 14 years then :) Thanks everyone!
Best regards,
                 Chris Wilson.
