I have an audio power amplifier here which uses a toroidal transformer. It is a Crown XLS-402D
This amplifier is suffering from a very common fault with this model (according to Crown themselves when I phoned them) where the transformer is shorted.
I discovered this by connecting the transformer to the mains with the intent of measuring the output voltages, only to have it trip the RCD (of course because the Live to Neutral is shorted).
I am wondering if any of you here have some experience re-winding Toroidal transformers and could give me some pointers?
Why is it faulty?Unfortunately, crown in their wisdom, decided to not put any insulating material on the inside of the lid of this model amplifier, resulting in, when something heavy is placed on the lid, the lid touches the top of the transformer mounting bolt.
Now as far as I understand it, this effectively makes the mounting bolt another secondary winding, which being only a half turn will have a very very low voltage but a huge amount of current and therefore short the primary coil?? That is my educated guess.
I can clearly see that the lid of the amplifier is dented in right on top of the transformer, there is a little bump where the bolt head used to be (before the bolt was lost by the previous person to attempt repairing this amp). There is also a charred mark in this dent which I gather is where there was some arcing right before the death of the primary coil.
So I am pretty sure this is the fault. Does anyone agree with me on this?
What next?I asked crown about a replacement transformer and they do not sell them any more.
Boo!
I would like to point out that this amplifier was given to me free by my local music shop that gave up on it. Some people might just say to bin it! But that is no fun!
I would very much like to learn how to re-wind the transformer as a little project, I have nothing to lose so might as well try to rescue the amplifier from going for scrap.
Now first of all there is a label on the transformer which shows the output voltages.
There is a single primary winding which is for 240V.
Then there is a single secondary winding which has a centre tap marked 0V, two more 18.5V taps then two 67V taps.
Kind of like this:
Secondary Winding
67V 18.5V 0V 18.5V 67V
Primary Winding (240V)
But the label does not stat the power(W or rather VA) of the windings at all!
This is where I am a little confused as usually when I have looked at a transformer there will be a Watts or VA rating on the label.
I believe I have tracked down the Manufacturer:
http://en.fsnre.com/But that is all I can find for now, I can't find a datasheet.
