I blew channel 1 on my Siglent SDS1104X-E and I really would like to repair it, I locked myself in to the Siglent 11x series by buying the logic probe and a Siglent AWG. If anything id like a new GW-Instek MDO that has python built in as a second scope, but I wont have any money for that if I have to buy another Siglent scope to replace mine!
Anyways I combed through the front end of the channel 1 and I found some bad transistors, diodes, and a bad J-Fet. Hopefully that is the extent of the damage, it seems like an easy fix although the soldering has been challenging for me, with components being so small and so close. I managed to pull all the bad parts out of the scope for testing without damaging anything thankfully.
With some help in another thread I managed to identify all the components I need to order. I went to order them today and found out the J-Fet is already an obsoleted component! What the hell? Thus isn't an old scope!!!!
I need to find a SOT-23 J-Fet by Unisonic,
2SK508G-k52-AE3. I can not find anyone selling these except a few surplus sellers I guess, the websites I found them on all want you to message them for a quote. I filled out forms at one or two of the sites to get a quote on 20 and have not heard back! There are people selling the
2SK508G-T1B in sot23 on eBay but I don't think they have the same Idss current as the SK52.
Im not sure what to do, or if I can substitute the original J-Fet with a different one, this is a scope front end so I would assume everything is pretty tight tolerances. I have a few
J310s in sot23 the Idss is similar and there drain and gate voltages are 10 volts higher than the 2SK508G-K52. I just do not understand J-Fets enough to determine if something will work as a substitute in a scope front end!
