Author Topic: Recapping a Panasonic RF 930  (Read 861 times)
Offline watchmakerTopic starter
  • Self Study in EE
    • Precision Timepiece Restoration and Service
« on: October 30, 2024, 06:08:01 pm »
I treated myself to this radio as a kid, $40 USD in 1970, back when a dollar was still worth 80 cents. (Over $300 USD today dollars).  Had it for at least 2 decades (wife remembers it) but lost track of it.  Had the best sound and remember listening to Elton John on a NYC FM station while I was 90 miles away.
Anyway, somehow ran across it on eBay and they now sell for about $20.  OK, mono, but I got rid of all my stereo stuff when we moved.  Not even a TV.
The issue was 60 Hz hum with volume all the way down while listening with earbuds that was not present on Batt.   Cord reversal did not help.  OK.  Replaced the PSU caps
Still great sound although my ears are far from what they used to be (no one used hearing pro when shooting or using chain saws).
There were two things that made me take a second look.  First, Panasonic used the chassis as the high side and sent the negative end to the ckt board.
Question:  Why did Panasonic elect to do this?  I thought it was convention to send the negative to the chassis.  See attached schematic.  S3 is the selector switch (set to Batt) and S2 is the power switch (set to Off).  The positive terminal of the batt pack is sent directly to local ground (chassis).
The other thing is look at the board!  Can you imagine hand soldering and aligning this on a production line??  Very tight fits.  And although it uses AFC, it does a great job on selectivity and sensitivity.
Regards,
Dewey
Offline m k
Re: Recapping a Panasonic RF 930
« Reply #1 on: November 03, 2024, 01:29:48 pm »
Time was different, salaries also.
(VW Golf came '74)
Maybe they were still learning away from the old ways.
Or maybe they learned that it's better that way.
Advance-Aneng-Appa-AVO-Beckman-Danbridge-Data Tech-Fluke-General Radio-H. W. Sullivan-Heathkit-HP-Kaise-Kyoritsu-Leeds & Northrup-Mastech-OR-X-REO-Simpson-Sinclair-Tektronix-Tokyo Rikosha-Topward-Triplett-Tritron-YFE
The following users thanked this post: MuteMemory39
  • Self Study in EE
« Reply #2 on: November 04, 2024, 01:46:41 pm »
OK, there is no RF advantage.  THANKS!
I am still intrigued by the positive polarity of the ground.  I was a 2 year electronics vocational ed student in high school in the late 60s and even that era we were taught the ground reference is negative.  The US Navy used the same convention even though the USN did (and still does!) teach electron flow.
I may collect some other Panasonic schematics (pre and post 1970) to see when they came to their senses.
We visited my daughter this weekend and her husband is an EE/patent attorney whose clients include SkyWorks.  Like you, he was at a loss as to why anyone make that choice.
And I am still processing what the production looked like hand soldering all those components onto such a compact board.  I have two of these radios and the soldering is not well controlled. And all the final slug positions on the IF cans are marked.  Working there must have been Hell.
Regards,
Dewey
Offline m k
« Reply #3 on: November 04, 2024, 05:59:47 pm »
Maybe it has nothing to do with electronics, maybe it's economics.
No need to invent a wheel, no matter the shape of the old one.
Offline andy3055
« Reply #4 on: November 04, 2024, 06:24:44 pm »
Is it possible that the +ve ground was used because of the PNP transistors they used at the time? This was very common those days.
As for the hum, check or replace C54, 55 and 58.
« Last Edit: November 04, 2024, 06:30:09 pm by andy3055 »
Offline MuteMemory39
« Reply #5 on: January 08, 2025, 12:05:18 pm »
I'm having trouble reassembling the pulley system for the tuner dial on my Panasonic RF-930. The string that guides the tuner rail came unstrung during repair, and I'm struggling to find the correct way to rethread it.
Can you provide guidance or point me in the direction of a resource that might help me put the pulley system back together correctly? I'd greatly appreciate any advice or support you can offer.
A picture?
Offline m k
« Reply #6 on: January 08, 2025, 03:21:51 pm »
Maybe you should take a picture also.
Who knows what differences there can be.
  • Self Study in EE
« Reply #7 on: January 09, 2025, 11:45:12 am »
Here is the page from the SM (933 is just variant)  Don't get frustrated, it is not that hard once you see it.  You will need a plastic/wood tool to ease the last bit over the pulley without fraying it.  You also need to release the indicator from the string and reset after it is restrung.
I have three of these radios and even put an LED COB string on the indicator backplate ledge for dial lighting.
Can you imagine being on the production line hand soldering those boards and assembling the final product?  I think they are interesting examples from an era where things were done very differently.
Regards,
Dewey
