Author Topic: recognize component and diagnosis  (Read 816 times)
Offline DaxxinTopic starter
« on: April 12, 2020, 05:24:08 am »
hi here bottom of mobo pcb got troubles with boot look at this component and pls help to discover cause of this.
The following users thanked this post: at_sr
Online coromonadalix
Re: recognize component and diagnosis
« Reply #1 on: April 12, 2020, 05:29:57 am »
If a part explose like this  causes could be  wrong polarity, excessive voltage, short circuit, bad manipulation, static discharge, part who has failed ??
Many things can happen
What is this board ? a tv a monitor ?   model, brand  needed  we are not magicians, we need more details
What happened, and take a bigger photo of the damaged part,  cant see the part number
Offline bob91343
« Reply #2 on: April 12, 2020, 05:38:31 am »
Well it's U23 so look in the parts list.  Maybe it's a voltage regulator.
I recently found a burned resistor in a voltmeter.  I replaced it and solved that problem, but analysis shows that the resistor had to be defective because there was no mechanism for it to overheat.  It had changed from 100 Ohms to several thousand Ohms and was in a constant current circuit.
Offline helius
« Reply #3 on: April 12, 2020, 07:01:10 am »
Is it NJM78L10A? 10V LDO regulator
