So I plugged this fan in the other day and seen the display illuminate for a split second and then go dark. First thing I did was check the fuse in the plug, but the fuse is fine.
I found a website where someone tried to modify this exact fans behavior with an Arduino. They had the fortune of their fan still working so they were able to locate the displays power pins and check voltages on it.
I measured these two pins and have nothing at all on them. I checked for a short and there is no short between these pins. I have uploaded what I think is an accurate schematic of the power supply.
There is a few things I left out which I suspect is just the circuity that controls the relays and powers the motors. I might have left something important out, but with trying to not waste to much time drawing the entire board out, I stopped with what I think was necessary. (I am most likely missing something necessary.)
Anyways, In hopes I can get some help from people much more knowledgeable than I, I have uploaded my schematic.
Does this make any sense whats going on, how is there supposed to be 5V at the output when connected directly on mains, etc. What might be bad in this? I checked the transistor with a meter and it tested good with that. Diodes are good too as far as my meter says.
