Author Topic: [SOLVED] Red varnish-glue for locking screws and bolts, electronic glue  (Read 1119 times)
Offline electr_peterTopic starter
  • Country: lt
I need some external locking solution for small screws/bolts. I have seen a thread on EEVblog before but can't find it anymore.
It is semi-transparent substance, red in color glue (like honey), put on screw/bolts externally to mark that they are locked and prevent them from loosening (or at least mark loosened ones). Easily removable. Household equivalent is red nail varnish. It is not locktite for internal threads, that's a different thing.
How is this substance called and where to get it?
« Last Edit: February 09, 2022, 10:05:51 am by electr_peter »
Offline Audiorepair
Re: Red varnish-glue for locking screws and bolts
« Reply #1 on: February 09, 2022, 08:16:53 am »
"Anti tamper" is one such product.
Not sure how effective a thread locker it is, but ok to seal presets against vibration.
https://uk.farnell.com/electrolube/blr10sl/adhesive-antitamper-red-10ml-syrge/dp/1841559?st=tamper
Online jpanhalt
« Reply #2 on: February 09, 2022, 08:17:25 am »
Are you looking for "anti-tamper" indicator?  Many manufacturers.  Here's one: https://www.newark.com/electrolube/blr15ml/sealant-bottle-15ml-red/dp/44AC2379
  • Country: lt
[SOLVED]Re: Red varnish-glue for locking screws and bolts, electronic glue
« Reply #3 on: February 09, 2022, 10:05:09 am »
Thanks for suggestions. I think I found right search terms.
Anti-tamper seal products become hard and brittle, like nail varnish. I was after something softer like "electronic glue" or "threadlocking adhesive silicone sealant". "Kafuter K-200R" product fits the bill, it will limit loosening of screws.
Offline Oilngas
Re: [SOLVED] Red varnish-glue for locking screws and bolts, electronic glue
« Reply #4 on: February 10, 2022, 03:08:15 am »
Perhaps you are thinking of "Glyptal".
http://www.glyptal.com/products/1201tech.pdf
Lots and lots of VTVM's and Triplett analog multimeters
