Electronics => Repair => Topic started by: MarkC on November 21, 2024, 05:53:47 am
Title: Reflowing/reballing a GPU core
Post by: MarkC on November 21, 2024, 05:53:47 am
I have my first GPU core to reflow/reball and I am seeking advice on the equipment.  About a year ago I got myself an Atten 862D and learnt how to do memory IC's and smaller BGA packages but I am aware that it alone will not do a core.
So, do I just need a good preheater and the hot air will do the rest or do I need to invest in an IR rework station?  I don't mind buying an IR station if they are needed but are they needed?  Thanks all.
Title: Re: Reflowing/reballing a GPU core
Post by: Harry_22 on November 21, 2024, 06:30:09 pm
Hello!
Good approach!
Yes you must have a bottom preheater.
A Z-axis platform and an infrared pyrometer would also come in handy.
I think if you set the temperature correctly and transfer the heat to the soldering area, then nothing else matters.
To do this, it would be good to understand the basics of thermodynamics.
My colleague uses the minimum set. And doing very complex work. All depends on the experience that you will undoubtedly gain.
Attached is a video of him rolling balls.
https://youtu.be/DVTxHx0z-wo?si=86rTudL4U7HKT8qv
PS
Could you attach the photo of your board to understand the dimensions.
Post by: electronix27 on November 22, 2024, 12:42:00 pm
Check out this fella's website, he does all sorts of these type of repairs, with more than one type of re-balling method.
https://www.youtube.com/@dosdude1 (https://www.youtube.com/@dosdude1)
Post by: keymaster on November 22, 2024, 06:36:04 pm
Another good source for gpu repairs and gpu reballing video is northwestrepair  (https://www.youtube.com/@northwestrepair (https://www.youtube.com/@northwestrepair))
