I'm a newbie but not sure if this belongs here or in beginners..
I have a plug in AC/DC wall adapter that broke a few years ago and has been sitting in a box. It's a Roland/Boss power adapter for powering guitar effect pedals. I believe the original problem was that output was intermittent but checking it now, I'm getting nothing from the DC output lead.
I think the problem is due to a broken ceramic capacitor. I'm trying to identify a suitable replacement. I have the capacitor removed from the circuit and I tested it with my multimeter (a Brymen BM257s) in capacitance mode. Normally with the probes not touching anything, the display shows all zeroes. When I test it on this capacitor, the zeroes disappear and I just see a decimal place.
When reading another ceramic capacitor, I see the expected 22uf value show on the multimeter. So I think I'm doing things correctly
The PSU itself is the BOSS PSA-240 and is the older non-switching model. It's a basic enough job that takes in 230 volts AC and puts out 9v DC, 200ma. Uses a transformer, bridge rectifier (4 diodes), 3 caps (two electrolytic and the ceramic in question) and then a 7809 regulator.
Can anyone help determine what replacement value to use for the ceramic cap? The markings on it are tiny and faint - it looks like 'KDE' (or KRE?) with '040-2' written below. From looking at the PCB, It's situated between the live/hot output of the transformer and the bridge rectifier. I've not seen this configuration in any of the standard PSU schematics online.
The other two caps are a 10v - 100uf located after the output of the voltage regulator, and a 25v - 2200uf located before it.
I've attached a picture of the capacitor and also the PCB with the parts marked as best I can.
Thank you
