Author Topic: Relay buzzing unless hooked after ESP8266 boots up.  (Read 893 times)
Offline nardevTopic starter
  • Country: ba
« on: February 23, 2018, 05:22:16 pm »
I believe that it would be proper way to put the whole project description but i hope it might be enough for someone with experience.
So, very simple thing.
I power up ESP8266, it boots, everything works fine.
I hook one of those cheap songle relay module boards (i tried other relays too, same thing) and controlling the relay works perfectly. No issues there.
However, if i leave it like that and restart EPS (power down/up), the esp never boots up, and there is silent buzzing from the relay.
Probably this might be all you need:
Between the ESP IO pin and relay board i have 1K resistor, 2n3904 NPN transistor and it switches 5V relay powered from external 5V.
Any clues?
  • Country: ba
Re: Relay buzzing unless hooked after ESP8266 boots up.
« Reply #1 on: February 23, 2018, 05:25:43 pm »
Any clues?
 |O |O |O |O |O |O |O
Just as i wrote this, i realized.. why the hell do i have only 1K there :) lol.. doesn't buzz any more...
Offline ArthurDent
« Reply #2 on: February 23, 2018, 05:58:33 pm »
See you got it working. Maybe you have already seen this but there is good information here for future reference.
https://www.forward.com.au/pfod/HomeAutomation/OnOffAddRelay/index.html#single5V
« Last Edit: February 23, 2018, 06:02:19 pm by ArthurDent »
The following users thanked this post: nardev
  • Country: ba
« Reply #3 on: February 28, 2018, 05:58:11 pm »
THnx
p.s. one of the issues was that MCU had pull-up on the pins i used my default.. so.. it even made more confusions..
« Last Edit: February 28, 2018, 06:00:46 pm by nardev »
