Author Topic: reload firmware on siglent SDG810 func gen  (Read 2383 times)
Offline teletypeguyTopic starter
« on: July 26, 2021, 05:07:40 pm »
Hi folks:
Does anyone know how I can re-load firmware into a siglent SDG810 func gen?  It served me well for years and then just hung at the boot screen.  Siglent sent me files/instructions for reloading from usb, but that does not work.  A note in the instructions indicates that a min level of existing firmware needed to be present and I presume mine is earlier than that.
I opened it up, looking for a programming port (I have various jtags pods...) but saw no obvious connector or pad arrangement.  There is an sd card socket on the board however, so I am optimistic that code can be loaded via a card, however I get no response from siglent on that possibility.
I have a siglent spectrum analyzer which is actually pretty nice, and a 350MHz scope which is ok, but I recently got an SPD3303C power supply which had an out-of-box dead channel (they replaced it), and now this generator fail, so I am kinda burned out on siglent.  I have moved to a keysight scope and got a rigol func gen, both of which I love.
But I'd hate to toss the old SDG810 and would like to re-flash it and give it to my son.  Anybody have any pointers?
thx, gil
Re: reload firmware on siglent SDG810 func gen
« Reply #1 on: July 28, 2021, 04:46:30 am »
Welcome to the forum.
Send me a PM with your email and together we can recover it.
The following users thanked this post: teletypeguy
« Reply #2 on: July 29, 2021, 04:26:29 am »
A great-big high-five to Rob at Tautech!
Offline perieanuo
« Reply #3 on: July 29, 2021, 07:14:17 am »
the idea i got when i joined this forum was that the help from community was public
« Reply #4 on: July 29, 2021, 07:47:34 am »
While I may be part of this community too Siglent trust me with a very special SW toolset that is not for public use.
If you need help we can sort out any problems in private.
Offline pedb
  • Country: br
« Reply #5 on: March 23, 2024, 04:46:06 pm »
Hi! I have the same issue, tautech, would you still have those files to send to me?
My siglent is freezing when I boot, it blinks and stays in siglent screen. SDG810.
« Reply #6 on: March 23, 2024, 07:49:12 pm »
Send PM with your email address.
Offline widi
« Reply #7 on: November 01, 2024, 09:40:34 pm »
Hi guys, I'm new to this forum and I want to say hello to everyone.
I have a problem with my Singlent SDG 810, which for some reason has stopped working, it has hung on the boot screen, and I don't remember what firmware version it has, in fact as always it has worked very well for me, I haven't seen the need to check it.
Can you help me to reload the firmware on my function generator?.
Thanks in advance :-BROKE
Offline widi
« Reply #8 on: November 01, 2024, 09:43:18 pm »
Thanks in advance
« Reply #9 on: November 01, 2024, 09:44:17 pm »
Thanks in advance
Siglent EU HQ in Germany can supply you with the USB recovery tool.
info-eu@siglent.com
Offline widi
« Reply #10 on: November 01, 2024, 10:48:13 pm »
Thank you for your help, very kind, I will contact them to see if they can help me.
I will comment on the support response and the solution they give me.
Again, very grateful. :bullshit:
Offline widi
« Reply #11 on: November 08, 2024, 08:30:55 pm »
Thank you tautech, for your invaluable help, I made the consultation with Siglent in Germany, they gave me support to some extent, I explain only helped me to perform a system restore through the usb, but this did not work, in my device I have never used the usb connections, which has in endowment, so I do not know if they worked or otherwise as a result of the fall of the operating system has stopped working, I just do not know.
As this did not work, I got back in touch with the support and the solution they gave me was to send my generator for verification.
Of course, this without certainty that it will work properly again, what surprised me is that at no time did they contemplate providing me with the option to perform a reset through the micro sd memory that is provided.
Does anyone know anything about the initialisation of the generator through the micro sd memory?
Thanks again
 |O
« Reply #12 on: November 08, 2024, 11:34:53 pm »
Thanks again
 |O
I know plenty about SD card recovery, which for early/old SDG800 that have never had FW updated is reliable although the process is a little complex.
EU and US HQ are reluctant to share SD card recovery as it seems they think it is beyond the capability of the average Joe....  :bullshit:
Send PM with your email, SN# and any info you have on any FW updates you have done.
Offline widi
« Reply #13 on: November 09, 2024, 08:48:39 am »
Thank you Mr. tautech for your valuable help, thank you for being here among us. :scared:
Offline widi
« Reply #14 on: November 09, 2024, 08:15:36 pm »
Hello.
I have no words of thanks to you Mr. Rob, for the unconditional help you have given me, THANK YOU VERY MUCH.
The generator is now in perfect condition and operational.
It is also updated to the latest version.
Eternally grateful Mr. Rob :bullshit: :-+
Kind Regards.
« Reply #15 on: November 09, 2024, 09:00:17 pm »
Hello.
Kind Regards.
:clap:
Did you notice the present Siglent gave you with a successful recovery ?
SDG810 > SDG830.
Offline widi
« Reply #16 on: November 10, 2024, 09:06:52 am »
Hello.
Kind Regards.
:clap:
SDG810 > SDG830.
Good morning.
Of course it is, but it was thanks to your intervention, and it must be emphasized that all those who work with Siglent do not have the same approach that you have, which makes people loyal to this brand.
Kind Regards
Offline sonicbuzz
« Reply #17 on: November 15, 2024, 03:46:52 pm »
I am having the same issue "SDG810 function generator stuck on the SIGLENT logo"
Can you please provide a recovery method?
How can I PM tautech?
Offline Haenk
« Reply #18 on: November 15, 2024, 05:25:37 pm »
[EU and US HQ are reluctant to share SD card recovery as it seems they think it is beyond the capability of the average Joe....  :bullshit:
That's probably because Joe Average is the typical customer targeted when offering function generators >:D
Most electronics guys did not get the concept of "computers" "SD cards" "press button A, then B" yet.
Just kidding (a bit), I very much appreciate you help (even though I did not need it, yet).
Offline sonicbuzz
« Reply #19 on: November 15, 2024, 06:04:55 pm »
tautech ... Thank you
Too bad the manufacture doesn't provide this information on their site or troubleshooting guide.
