Author Topic: Remote Control Batteries Lasting a Day  (Read 863 times)
Offline Chet T16Topic starter
  • Country: ie
    • Retro-Renault
« on: January 02, 2024, 10:43:52 am »
Hi All,
I've a remote control from a NowTV/Roku that is using up its 2xAAA batteries after a day. Other than that its working fine. I've taken it apart and there was some slight signs of water damage which i've cleaned up.
Measuring between the battery terminals gives me a resistance of ~120 ohms so that explains the battery drain.
I'm unsure how to approach fault finding now, if it was a direct short i'd try getting some current through it and see what heats but it'll take a while to heat as it is!
Any suggestions?
Chet
Paid Electron Wrestler
Offline Psi
Re: Remote Control Batteries Lasting a Day
« Reply #1 on: January 02, 2024, 12:03:54 pm »
Check with your phone camera on the IR output end to see if its constantly sending some IR data indicating that it thinks a button is being held down.
Ya can't prove a negative but its worth checking (some phone cams show IR better than others, maybe check your phone with another IR remote to see)
Offline Haenk
« Reply #2 on: January 02, 2024, 12:53:19 pm »
Googling reveals that battery eating is a known problem on these.
  • Country: ie
    • Retro-Renault
« Reply #3 on: January 02, 2024, 08:58:12 pm »
It's a known issue that they'll run down in about 2 weeks but this is within a day. And another remote I have doesn't have the same resistance between the terminals
Chet
Offline BrokenYugo
« Reply #4 on: January 03, 2024, 04:16:45 pm »
There's generally almost nothing in these but the button array and a blob chip, maybe a decoupling capacitor, and a ceramic resonator with loading caps for the clock generator. If cleaning doesn't fix it and the decoupling capacitor across the power supply hasn't gone leaky there isn't much more you can do.
  • Country: ie
    • Retro-Renault
« Reply #5 on: January 04, 2024, 06:16:22 pm »
Theres actually no blobs in here, theres an MSP430 and OZMO2000 radio IC amongst others
Chet
Offline floobydust
« Reply #6 on: January 04, 2024, 07:36:54 pm »
Post pics of the board.
I had a Sony remote the 100uF electrolytic cap on the main rail was installed backwards, it didn't pop at -3V but did kill batteries.
You might have a shorted MLCC or IR driver etc. look around for the low resistance.
