Hi all.
I am restoring an old Sanyo DCX-2000 radio receiver/ amplifier.
I need to remove the faceplate but in order to do that, the tuning knob needs to come out.
Unfortunately, it seems that the little screw that keeps it in place is botched
I tried using a flat head screwdriver, hex, philips, torx, triangle...everything failed. Sheding some light in the hole, revealed what I was afraid of.
I am attaching a picture that might help, unfortunately, i can't get a better shot...
My questions:
- is there any way that I can remove the screw without damaging the dial?
- is it possible that this may be some kind of special screw? I found no relevant info in the service manual.
- where can I buy a replacement knob?
I have been looking around for replacement parts, but so far I had no luck, so any hints are more than welcome!
Thank you very much in advance!!
Michalis
