I got all the sticky springs sorted out and have now run the self tests.
All voltage ranges appear to work for both AC and DC with reasonable results (haven't checked accuracy yet). Resistance measurements (4 or 2 wire) always show around 10 ohms when any resistor is connected.
All tests except 2, 10, 11, 12 pass. 2 is the CPU and likely some bit rot in the ROM. Both CPU and RAM have been replaced in the past (flux residue). I'll address that later probably with a ROM swap (7 digit firmware?). 10, 11 and 12 are all out by at least a factor of 10. This corresponds with the ohms readings being bad. According to page 8-59 of the service manual, the last 3 tests failing all point to the ohms function being bad so I'm guessing the current sources. When inputs are open 10G and 1G ohm ranges both show 0, other ranges show OL. Service Group D is the next step.
