Am I the only one thinking that those electrolytics may be perfectly OK and don't need changing at all?
Harumph. Yes, having been able to look at the circuit diagram since my first post, I am tending to think that for the electrolytics. However, they are 1989 vintage, so 30 years old...
<expletive deleted> Rifas have to come out, though.
If noise is coming from the SMPS, I would be looking at the secondary side of the converter first.
Most definitely; I'm just going through the parts list.
In fact there are two separate switching PSUS, one for the main body and one for the CRT.
Having waved a scope probe around in the air, it looks like the CRT is at the right frequency, and that matches something I've seen on the groups.io mailing list.
I'm also checking a few tant beads, too.
If you absolutely need to remove those caps, I would use my favourite method: cut the soldering joints flush and drill them through with progressively larger bits, from 0,5mm to 1mm, to 1.25, 1.50 and even 2mm, until the hole is clean. Make sure to be dead center, though.
I haven't heard of that interesting technique, thanks. I'm unconvinced I could satisfy that caveat
