Author Topic: Removing old conformal coating?  (Read 1424 times)
Offline TERRA OperativeTopic starter
  • Country: jp
  • Voider of warranties
    • Near Far Media Youtube
« on: January 16, 2019, 03:50:13 am »
I have an old bit of HP gear that I am giving a spit polish (5005A Signature Multimeter) and the conformal coating/clear spray coating on the PCB's is looking a bit blegh and could to with a fresh application.
I found when cleaning the boards with isopropyl alcohol that the coating started to go a bit tacky and in some places I could rub it off with a bit of effort.
I'm wondering if there is any product that I could use to dissolve the coating somewhat easily but one that wont damage the silkscreen or components?
Anyone have any suggestions to try?
Offline Tomorokoshi
Re: Removing old conformal coating?
« Reply #1 on: January 17, 2019, 02:40:10 am »
Does that seem to be a clear, hard coating or that soft coating?
I looked in the 5005A manual and I couldn't find the conformal coating listed, so determining what works might require experimentation.
If it's the clear hard coating, then it might be acrylic. I have experience with Humiseal 1B73:
http://www.humiseal.com/products/aerosol-products/1b73/
But I have not used the remover:
http://www.humiseal.com/products/strippers/st-1080/
For my own boards I just use Rustoleum Crystal Clear Enamel. It's also acrylic based:
https://www.rustoleum.com/product-catalog/consumer-brands/stops-rust/clear-enamel
Something similar may be available in Japan. Maybe at places like Doit or Homepic.
  • Country: jp
« Reply #2 on: January 17, 2019, 05:25:59 am »
It is a hard clear coating, I think a type of acrylic laquer.
Isopropyl alcohol doesn't really touch it much, (the coating only gets a little tacky) but methanol does, except methanol also takes off the silkscreen too....
Replacement coating is easy enough to find here in Japan, but I just gotta get the old stuff off first....
Offline tru3533
  • Country: no
« Reply #3 on: January 17, 2019, 05:44:18 pm »
Have you tried to find the glass transition temperature?
The glass transition temperature is the temperature range where the polymer substrate changes from a rigid glassy material to a soft (not melted) material.
Heating the board to around 100 degrees celsius works great in many cases. (boiling water)
And then the substrate can be removed easily with a flat bamboo stick or similar.
