Trying to bring an HP 3312A function generator back to spec, but, and this must be a common problem, I can't remove one of the knobs. There maybe more, this is the first one I've tried to remove.
See photo - the Vernier knob removed OK, but the 4 position switch knob is absolutely stuck.
I've got the right hex key, it fits the grub/set screw correctly, but I cannot turn it. I'm worried I might strip the internal hex.
Any ideas? Maybe gentle heating, some sort of lubricant or releasing stuff?
Thanks
Charles
