Hello!
I'm newbie. Seeking help please to troubleshoot my desoldering station. It was unused for few months while waiting for the soldering tip replacement when it was replaced the magnetic valve for the vacuum pump won't turn off. Normally it will only turn on when button is pressed from the soldeing tip. Any thoughts or solution to my problem? I checked all the connection and looks fine. Thank you.
Cheera,
Marlon
