Author Topic: repair: 3com Baseline Switch - model 2808  (Read 5061 times)
Offline What_NZ
« on: June 19, 2014, 03:46:45 am »
Hi there, thought his may be of use to someone.
I was presented with a 3com 8 port Network Switch, that was either not working or working just for a short time.
The first thing I noticed after inspection was the Power LED flickering and/or then going out all together.
After opening the unit up I was presented with a very nice design consisting of 2 circuit boards (Logic board and PSU)
Since this appeared to be a PSU fault, I was drawn to it first. Almost instantly I saw the old bulging Capacitor problem.
Immediately I thought cheap Chinese caps but then I thought no wait this is 3com, surely not!
Just goes to show you it's not always the cheap ones that fail.
Shown below are the Nichicon capacitors that have failed, I hope you can see the bulging top. I have ordered some excellent quality Panasonic's but the unit is working perfectly with some temporary one's.
« Last Edit: June 19, 2014, 10:10:43 am by What_NZ »
Online NiHaoMike
    • Facebook Page
Re: repair: 3com Basline Switch - model 2808
« Reply #1 on: June 19, 2014, 04:01:04 am »
I recommend adding a tantalum or ceramic cap or two in parallel (10-100uF or so) to catch the high frequency ripple. Had a similar issue in a Cisco router causing random reboots (the router was only 2 years old at the time, so much for "good quality"...), which I fixed by swapping the caps with salvaged OSCONs and then it just kept working an additional 5 years until I decided to upgrade it.
Offline What_NZ
« Reply #2 on: June 19, 2014, 04:40:17 am »
Interesting but my rule of thumb is that I don't modify what I didn't design. It is however good news that the changes you did worked well.
Offline retiredcaps
« Reply #3 on: June 19, 2014, 05:48:36 am »
Nichicon had a bad run of HM/HN series capacitors in 2001-2005, if I recall correctly.  If those capacitors are in the date range, it could explain a lot.
However, regardless of brand, some designs like those small form factor PCs running Pentium 4s at 3.0Ghz, will cook any capacitor over time due to excessive heat.
Offline What_NZ
« Reply #4 on: June 19, 2014, 06:04:48 am »
Yes it could well be a bad batch. When I get a chance I'll see if there is a visible date code. Actually this unit runs very cool and it is in a temperature controlled room.
Offline PedroDaGr8
  • A sociable geek chemist
Re: repair: 3com Baseline Switch - model 2808
« Reply #5 on: June 20, 2014, 09:49:55 pm »
Retiredcaps  is correct.  The Nichicon issue is unrelated to the bad caps issue though the symptoms are the same.  For the bad caps, cheap electrolyte breaks down eventually venting and killing the cap.  For the Nichicon caps, they accidentally over filled the caps with electrolyte.
The very existence of flamethrowers proves that some time, somewhere, someone said to themselves, "You know, I want to set those people over there on fire, but I'm just not close enough to get the job done." -George Carlin
Offline Bored@Work
« Reply #6 on: June 21, 2014, 04:47:40 am »
What? You are substituting parts? Hahaha.
Offline What_NZ
« Reply #7 on: June 21, 2014, 07:19:45 am »
Huh? and what is wrong with replacing 1500uF 6.3vDC 105C low ESR capacitors with 1500uF 6.3vDC 105C low ESR capacitors. If you are going to post something at least try to make it intelligent.......
« Last Edit: June 23, 2014, 01:55:53 am by What_NZ »
Offline What_NZ
« Reply #8 on: June 23, 2014, 02:09:04 am »
Just received the replacement capacitors today. The failed Nichicon's are labelled as HM(M) with codes H0424, H0341. There are also 3 others which are ok but I replaced them on spec as codes are also H0424 and x2 H0341. I'm not an expert on Capacitor date codes but if I get time I'll go to their website and have a look.
Update: the date code is ?yyww so H0424 is 2004 week 24, H0341 is 2003 week 41 and so they fall within the "bad run" years you mentioned.
« Last Edit: June 23, 2014, 03:00:35 am by What_NZ »
Offline What_NZ
« Reply #9 on: June 23, 2014, 02:29:21 am »
Just thought I'd post some pictures of the capacitor replacement. I use a Pace Soldering/ De-soldering Station MBT201, which uses vacuum suction for de-soldering and it is fantastic on heavy supply/ground planes.
So here are some photo's. The final test was checking these power supply lines and a soak test for 3 hours.
« Last Edit: June 23, 2014, 02:41:31 am by What_NZ »
