Poll
i am trying  to fix my water heating rod . solder is not holding well inside bcos of temp what else can i use to join wires?
not hot glue
3 (75%)
not tape
1 (25%)
Total Members Voted: 4
Voting closed: January 07, 2015, 06:35:52 pm
Author Topic: repair  (Read 2469 times)
Offline AkashthakurTopic starter
repair
« on: December 31, 2014, 06:35:52 pm »
please answeer
Offline tom66
Re: repair
« Reply #1 on: December 31, 2014, 06:42:12 pm »
If solder is melting, hot glue and tape will definitely melt!
Or do you mean, the solder does not adhere? Because you can't solder to all surfaces.
Offline lewis
  • Nullius in verba
Re: repair
« Reply #2 on: December 31, 2014, 06:44:52 pm »
Crimps or a ferrule
I will not be pushed, filed, stamped, indexed, briefed, debriefed or numbered.
Offline HighVoltage
Re: repair
« Reply #3 on: January 01, 2015, 11:17:18 am »
In the USA I have seen plumbers use something called JB-Weld, an adhesive that works on metal pipes and I was surprised that they could plug a bad pipe ate least temporary.
Offline Simon
  • Global Moderator
    • Simon's Electronics
Re: repair
« Reply #4 on: January 01, 2015, 09:25:11 pm »
I have locked this topic as it makes no sense whatsoever. My guess would be that it is potentially an attempt at spam or that the original poster has such poor English that he is not formulated a question which makes any sense whatsoever.
