Author Topic: Repair Acer AL2223W Monitor - Comes on for a Second then Screen Goes Black  (Read 3147 times)
Offline tpowell1830Topic starter
  • Peacefully retired from industry, active in life
I have 2 Acer AL2223W Monitors and one of them has stopped working. When the computer boots up I get an Acer logo screen and then the monitor shortly goes black. Also, if I unplug the VGA cable and plug back in, the screen shows my desktop for a second and then goes black. I haven't opened the back yet to see what I can see.
I was hoping to get some feedback if anyone has ever seen this before. I just want to get an idea where to start looking.
Any ideas are welcome.
PEACE===>T
Offline Cupcakus
Check the electrolytic caps, that is almost always the culprit.  If they are bulging, they're easy to spot.  Just replace them all.
Offline netdudeuk
Shine a torch really close to the screen. Do you see the image ?
Offline james_s
Is this LED or CCFL backlit? I've seen the same problem with a TV I fixed that had a bad LED in one of four series strings in the backlight. I've seen it happen with a CCFL that had a bad tube.
Thanks to all replies. I did the deed and opened the back and found a bunch of bulging caps on the power supply. I am in the process of replacing them now.
I will update when I get them in and tested.
PEACE===>T
Offline james_s
Sounds like you're on the right track, I bet it will work fine once you replace those.
I remember when LCDs first came out everyone was moaning that they'd be impossible to repair. Surprise surprise, turns out they have one of the same problems that CRTs had. I've fixed dozens of them by replacing capacitors.
Offline Kim_555
    • Laptop repair.
After the power supply is malfunctioning, the processor may be damaged. Perhaps replacing capacitors to nothing lead. Since the condenser when dry - loses its parameters, and the voltage that it must filter - comes to monitor circuit.
Regards.
Offline james_s
I've repaired dozens of LCD monitors and TVs by replacing capacitors. Usually when I get them they won't turn on at all though. Only a small number of them were not resolved when the capacitors were replaced.
