Author Topic: Repair Agilent N9010A - Need support find 120 ohm resistor  (Read 1379 times)
Offline chinhchengTopic starter
  • Country: vn
« on: September 01, 2022, 03:49:30 am »
Hi All
I am a newbie here, I am repairing Agilent N9010A in a local company in Vietnam
Service Engineer said to me that it broken resistor with value 120 ohm (that attached in an Attenuator Part), please see image, but he don't know how to buy it
Is there any body know this. Please help me to know where I can buy this resistor.
Thank you so much in advance.
« Last Edit: September 02, 2022, 10:11:51 am by chinhcheng »
Offline Mario87
Re: Repair Agilent N9010A - Need support find 134.7 ohm resistor
« Reply #1 on: September 01, 2022, 07:32:57 am »
2nd image looks like you have 3 of these resistors in parallel with an empty space at the top where I assume the broken one should sit.
How was the resistance measured? Did the service engineer take out each resistor and measure individually or did they just measure from 1 side of the 3 resistors in parallel to the other side? With 3x resistors in parallel 137.4 ohms would be 412.2 ohms per resistor which means you are really looking at a 412 ohm resistor with probably a 0.1% tolerance level
412 ohm SMD resistors should be a bit easier to find from the usual sources.
  • Country: vn
« Reply #2 on: September 02, 2022, 10:11:26 am »
Hi Mario87
Thanks so much for your response, you true,
He just checked it again, in the first picture, it is 4 x 120 ohm registor for level atennuator is 10 dB
The other attenuator level is 6 dB, 20 dB, 30 dB are not as bad as failure, but there is error.
  • Country: vn
Re: Repair Agilent N9010A - Need support find 120 ohm resistor
« Reply #3 on: September 04, 2022, 06:48:35 am »
Up!  :-// :-// :-//
  • Country: vn
« Reply #4 on: October 04, 2022, 08:00:35 am »
These resitor is a component in below attenuator,
PN: 3321-6080-64-1305-V10352
Offline HighVoltage
« Reply #5 on: October 04, 2022, 08:36:28 am »
I would assume that these resistors are made and trimmed by Agilent or some special supplier to Agilent.
You will not be able to get exact this resistor as a replacement part.
You may use other resistors and trim to your needs.
But it will no longer match the original specifications.
  • Country: vn
« Reply #6 on: October 06, 2022, 12:21:47 pm »
Hi
Tks so much for your information, in this case, the solution is find another attenuator on ebay :(((
Offline qnhn90
  • Country: vn
« Reply #7 on: October 07, 2022, 06:57:55 am »
bạn tìm đc linh kiện chưa?
