Author Topic: Samsung LE40A616 LCD problem  (Read 494 times)
Offline T-5
« on: January 14, 2019, 12:41:05 pm »
Hi there!
I found a Samsung LE40A616A3F in the dumpster. The problem with it is that portions of the screen are very slow to update and show a lot os smearing. To me (not very experienced with problems like this) it looks as if the driving current/voltages to the LCD transistors are not strong enough, maybe a power supply issue? But see for yourself, I made a video:
https://t-5.eu/owncloud/index.php/s/ZqM43h4KW7nxDls
Is it repairable?
Thanks in advance!
J├╝rgen
Offline Armadillo
Re: Samsung LE40A616 LCD problem
« Reply #1 on: January 14, 2019, 01:06:20 pm »
Defective LCD Panel.
Offline T-5
« Reply #2 on: January 14, 2019, 05:30:14 pm »
how sure are you? inpercent? :)
Offline Armadillo
« Reply #3 on: January 14, 2019, 05:33:05 pm »
100%.
ONE HUNDRED PERCENT.   :D ;D
Offline T-5
« Reply #4 on: January 14, 2019, 06:47:31 pm »
Thank you very much for your input!
