Hi!
I got DPO7104 in very bad condition, looks like this device play footboall, as a result most bga get off from pcb.. with pcb traces off..
But!
I repair traces on PCB and find donor PCB for replace broken BGA IC, in this time device work fine! Like DPO7104 with many options. And it would seem that everything is fine.
SYSTEM INFORMATION:
Stingray
Model: DPO7104
Serial number: B010496
Scope.exe Version: 5.3.5 Build 22; RELEASE
Diagnostics:
Powerup mode: USER
Powerups Count: 88
Timed Demo Info: Timed Demo, 0 days left.
Options:
5RL
2SR
MTM
LSA1
PTM1
?p?
ASM
LT
DDRA
SR-EMBD
App 48
App 49
App 50
App 51
App 52
App 53
App 54
App 55
App 56
App 57
App 58
App 59
App 60
App 61
App 62
App 63
App 64
App 65
App 66
App 67
App 68
App 69
App 70
App 71
App 72
App 73
Hardware Configuration:
CPU Board Id: 1, 1
Windows Driver version: 1021D
MIA Image version: 10011156
ACL4 Image version: AC140707
Number of channels: 4
Acq board RevD/512
DEMUXES PRESENT: 8 DEMUXES IN USE: 8
ATODS PRESENT: 4 ATODS IN USE: 4
Track and Holds: 1
ACQ MEM: 536870912
ACQ BW: 1000
ACQ SAMPLE RATE: 5000
DEMUX ASIC REV: 0
FTL PRESENT: 0
Max Recovd Clk: 1.25e+009
CalFilter support: 0
BWE Support: 1
CF StandardBits: 0x00000000
BWE Bandwidth: 1.000e+009
BWE SampleRate: 1.000e+010
IsVista: 0
system configuration flags
PREAMP HFD144
PREAMP M668
50 ohm termination
1 meg ohm termination
Attenuator 10x
Trigger Serial
Trigger CAN
Trigger Pattern Lock
Advanced Search
Limit Test
DDR Search
Embeded Analysis
Trigger Video
Comm Option Enabled
digPhaseCal succeeded
But....
I hear whisper, from this device, -You underestimate my POWER!! After hear this i wont give take full power to this device!! 1Ghz... For this monster, is not enough!
I found how to convince this device he is 3.5Ghz model!!!
In this time im take after start Tekscope.exe he is DPO7354!
SYSTEM INFORMATION:
Stingray
Model: DPO7354
Diagnostics:
Powerup mode: USER
Powerups Count: 5
Options:
10RL
MTM
Res
Res
LSA1
PTM1
?p?
ASM
LT
DDRA
SR-EMBD
ERRDET
STU
MSOE
SR-COMP
App 48
App 49
App 50
App 51
App 52
App 53
App 54
App 55
App 56
App 57
App 58
App 59
App 60
App 61
App 62
App 63
App 64
App 65
App 66
App 67
App 68
App 69
CPU Board Id: 1, 1
Acq board RevD/512
Track and Holds: 1
ACQ MEM: 536870912
ACQ BW: 2500
DEMUX ASIC REV: 0
FTL PRESENT: 0
CalFilter support: 1
BWE Support: 1
CF StandardBits: 0x00000F00
BWE Bandwidth: 3.500e+009
IsVista: 0
PREAMP HFD144
PREAMP M668
50 ohm termination
Attenuator 10x
CLock Recovery
Trigger Serial
Trigger Serial Ultra
Trigger CAN
Advanced Search
Limit Test
DDR Search
Embeded Analysis
Trigger Video
Comm Option Enabled
Serial Error Detect
But...
Popup message like "NVRAM file cant read for this device, dude go to tektronix service"
I wont write all consuption info and litlte photo about this DPO7k scope and how convince him that he is DPO7354!
But....
First i wont make sure everything is okay. For this i need:
Can someone who have access to this model DPO7354 (and 7254) copy here folders
C:\TekScope\calibration
and
C:\Program Files\Tektronix\TekScope\SYSTEM
I have no idea were NVRAM "file" in this scope..
I started this repair in June, this most hard reapir i doo, because of many BGA pad repair, tons pad BGA repair.
